I have a windows 2012 R2 server / 64 Go / 12To and unable to add device :
syncthing v0.14.54 “Dysprosium Dragonfly” (go1.11 windows-amd64) teamcity@build.syncthing.net 2018-12-05 11:18:45 UTC
The device was always dispayed for adding.
If I stop syncthing and edit manually config for adding the computer that’s work fine,
Seams to be a panic : ?
file “AppData\Local\Temp\dd_vcredist_amd64_20180927154235.log”): finisher: pull: peers who had this file went away, or the file has changed while syncing. will retry later
Panic at 2018-12-21T15:19:33+01:00
panic: runtime error: invalid memory address or nil pointer dereference
[signal 0xc0000005 code=0x0 addr=0x80 pc=0x92a8f2]
@Samuel_Bruyere Panic happens when a directory structure is replaced by a file with the same name. This seems like a rather unusual operation, even though it apparently happens quite frequently for you (or maybe just can’t be resolved once it’s happened once…).
