Hijacked from a support thread, hence lack of context for initial post. //@calmh
These are two different directories that you sync. The second may be due to enabling auto-accept folders. You probably want to add a Syncthing folder pointing at a location that you actually want to sync (and remove those folders, unless you actually need them).
@calmh @AudriusButkevicius Should we scrap the default folder? I think it does more harm than good, as users don’t need to go through adding a folder and thus seeing the “normal folder addition and sharing process” at least once. It’s there by default, but it doesn’t do anything as it isn’t shared with devices. Sure, I’d expect a user to notice the empty “Shared With” line, but I think it’s safer to not expect anything…
