I upgraded to 0.14.15 (32bits) my windows nodes and they are synking correctly. I upgraded to 0.14.15 (64bits) my ubuntu node but it’s not synking.
can some body help me ?
You’ll need to provide much more information. But first, look through the previous posts in the support forum for similar issues and try out the tips offered there.
Sorry, I don’t know which info I must provide.
On my servers I saw this message on the command window. 192.168.1.202 is my Ubuntu server
[F5TEY] 12:15:11 INFO: UPnP parse: unrecognized UPnP device of type upnp:rootdevice [F5TEY] 12:15:11 INFO: UPnP parse: unrecognized UPnP device of type upnp:rootdevice [F5TEY] 12:15:11 INFO: UPnP parse: unrecognized UPnP device of type uuid:0000000 0-0000-1000-0000-c04a00a5f456 [F5TEY] 12:15:11 INFO: UPnP parse: unrecognized UPnP device of type uuid:0000000 0-0000-1000-0000-c04a00a5f456 [F5TEY] 12:15:11 INFO: UPnP parse: unrecognized UPnP device of type urn:schemas- wifialliance-org:device:WFADevice:1 [F5TEY] 12:15:11 INFO: UPnP parse: unrecognized UPnP device of type urn:schemas- wifialliance-org:device:WFADevice:1 [F5TEY] 12:15:11 INFO: UPnP parse: unrecognized UPnP device of type urn:schemas- wifialliance-org:service:WFAWLANConfig:1 [F5TEY] 12:15:11 INFO: UPnP parse: unrecognized UPnP device of type urn:schemas- wifialliance-org:service:WFAWLANConfig:1 [F5TEY] 12:16:06 INFO: Dialer for 192.168.1.202: unknown address scheme “” [F5TEY] 12:17:06 INFO: Dialer for 192.168.1.202: unknown address scheme “” [F5TEY] 12:18:06 INFO: Dialer for 192.168.1.202: unknown address scheme “” [F5TEY] 12:19:06 INFO: Dialer for 192.168.1.202: unknown address scheme “” [F5TEY] 12:20:06 INFO: Dialer for 192.168.1.202: unknown address scheme “”
So either you screwed up you config or you upgraded from an ancient version. If you set the listen address or device addresses manually, they need to have the format described in the docs: https://docs.syncthing.net/users/config.html#listen-addresses https://docs.syncthing.net/users/config.html#device-element
I upgraded from 0.14.13 I have added :22000 and now is synking thanks
