Ubiquiti (UniFi) CyberSecure - Suricata- reports false SyncThing Threat
My UniFi Network Gateway runs Suricata and every hour or so I get a security alert which I believe is FALSE saying that one of my devices has traffic that is Blocked as it matches a known threat profile because a TOR exit group is used (at least that is what I think as all of this is a bit above my skill level). I can remove the alert based on IP address, but they seem to vary so I don’t think I can disable them on my end. Is there some way to turn this off in SyncThing. I am on the latest version of everthing. Running Mac OS Tahoe. I have turned off Enable NAT traversal, Global Discovery and Enble Relaying. Anyone actually solved this? See message below.
That is a relay connection, so disabling relaying is the correct answer and should work.
is there any way to do this on mobius sync?
No idea, you’d have to ask them.
A bit offtopic but is there still a reason to use Mobius Sync whit Synctrain being a thing now?
