Hi All
I am new to syncthing and some how did something I am having trouble fixing.
So maybe a couple weeks ago I decided to start syncthing manually from the command line and apparently, that started a whole new syncthing instance with a different device ID. I did not know this was possible. Without thinking much, I configured everything to work with all the computers and this time got it all working smoothly.
Well what I didn’t know, or forgot about, was that every time I reboot the server, Syncthing has a Syncthing service that starts automatically with a different device ID and my original test folders when I was fooling around learning the software. This device ID and config is no longer needed.
I would like my new config to start with the service. How can I point the syncthing service to the new config?
The new config I can get to and start easily by manually starting syncthing. It starts under a different port number as well. But I need to keep the command box open for syncthing to run the new config.
Thank you all Justin
The server is running Windows 10. Syncthing Ver 1.27.9
