Turning LAN compression off
How can I turn compression off for LAN connections?
Somehow I seem to be unable to find the config.xml documentation.
You cannot do that. You can only adjust whats compressed overall, not in LAN
Thanks for the quick response.
I’m going to open a new topic about my poor LAN transfer performance using incredible amounts of system resources. Hopefully there is another solution for this.
Hello,
Where can I find a relevant guide about compression options ? I’ve searched this forum and docs.syncthing.net, to no avail so far.
I’d just like to understand what compression means, what are its advantages and drawbacks (mainly on system resources) and choose accordingly.
Cheers.
If you have compressible data in your folders (text files, word documents, source code, …) set it to “Always” for best performance. If you’re syncing photos, movies, already compressed data like zip files, leave it at “Metadata”. Don’t set it to “Never” unless you have extremely low powered devices where every CPU cycle matters. And in that case Syncthing may not be for you at all. :smile:
Quick & neat, very thanks @calmh
PS : Syncthing, not for me? are you kidding? :stuck_out_tongue_closed_eyes:
Re.
Hello @calmh
I have ~ 20GB of documents, 70GB of music and ~10GB of photos, spread within different repos and, of course, different devices. What could be the best compromise for compression settings ? My main concern is the NAS, which has a less powerful CPU than other devices.
I usually set “never” for all devices in the same LAN and “metadata”/“always” for the rest, depending on the power of the other devices and the internet connection speed
Noted, this is my config : 1 Laptop, 1 phone, 1 tabled, 1 NAS, all on the same LAN, during weekend and in the evening. But I bring Laptop + phone + tablet at work, so they all access the NAS over the internet during the day. This is for over the same LAN vs over the internet.
On the other side, I’ve listed my repos to show the mix. All these being synced on the NAS, what would be the “ideal” compression settings for the NAS ?
Thanks.
as @calmh said because most of your files are music and photos you could set all to “metadata”
