Trusted/Untrusted share help needed
Hi! I have a Folder on Device Dev1 shared with devices Dev2, Dev3 (Untrusted) and Dev4 (also Untrusted). On Dev2, this Folder is one-way shared with Dev1.
How do I add a “circular share” with at least one of Dev3 and Dev4 (both Untrusted) on Dev2?
Thanks a ton for help!
Add it the same way you did on dev1, unless I’m misunderstanding something.
Hi Jakob, thanks for your answer! My concern is: if I go on Dev2 (Trusted) and I add Dev3 (Untrusted), should I put a password when activating Dev3? What if I don’t put any password, or a different one?
Yes you need to give Dev2 the same password you gave on Dev1 for it’s sync with Dev3.
Thanks all, that seemed to work!
