I am looking for a guide on how to set dataset permissions in Truenas Scale for the official Syncthing app.
Problem:
Syncing a file to the System does not work. I get a .tmp file at the correct location, but then the Sync stops and Syncthing reports “Out of Sync”.
What I found out:
I do not want to touch Syncthings config dataset and leave it owned by root. Syncthing seems to set permissions itself.
What I do not know:
How I set the permissions on the data folders I wish to sync.
Specs:
- TrueNAS Scale 22.12.0
- Syncthing App from the Official Catalogue
- Configuration and Data folders set as host paths
- User “apps” has full control over the data set it tries to write to.
output from log:
- 2023-02-25 15:28:28 Adding folder “test” (test)
- 2023-02-25 15:28:28 Ready to synchronize “test” (test) (receiveonly)
- 2023-02-25 15:28:28 Failed initial scan of receiveonly folder “test” (test)
- 2023-02-25 15:28:28 Error on folder “test” (test): folder marker missing (this indicates potential data loss, search docs/forum to get information about how to proceed)
- 2023-02-25 15:28:46 Cleared error on folder “test” (test)
- 2023-02-25 15:30:25 Puller (folder “test” (test), item “Avatar ext. 1.1.mkv”): syncing: finishing: setting perms on temp file: chmod /test/.syncthing.Avatar ext. 1.1.mkv.tmp: operation not permitted
- 2023-02-25 15:30:25 “test” (test): Failed to sync 1 items
- 2023-02-25 15:30:25 Folder “test” (test) isn’t making sync progress - retrying in 2m39s.
- 2023-02-25 15:34:16 Puller (folder “test” (test), item “Avatar ext. 1.1.mkv”): syncing: finishing: setting perms on temp file: chmod /test/.syncthing.Avatar ext. 1.1.mkv.tmp: operation not permitted
