I moved about 80TB and that worked great, but in the last week though things have stopped syncing. Not sure what
TrueNAS
2023-02-10 22:43:17 "Share" (aaaa-aaaaa): Failed to sync 38511 items
2023-02-10 22:43:17 Folder "Share" (aaaa-aaaaa) isn't making sync progress - retrying in 6h21m0s.
2023-02-10 22:43:46 Established secure connection to AAAAAA-AAAAA-AAAAAA-AAAAAA-AAAAAA at 172.16.0.125:22000-192.168.1.114:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256
2023-02-10 22:43:46 Device AAAAAA-AAAAA-AAAAAA-AAAAAA-AAAAAA client is "syncthing v1.23.1" named "System-A" at 172.16.0.125:22000-192.168.1.114:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256
2023-02-10 22:51:16 Connection to AAAAAA-AAAAA-AAAAAA-AAAAAA-AAAAAA at 172.16.0.125:22000-192.168.1.114:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256 closed: read timeout
2023-02-10 22:51:16 Established secure connection to AAAAAA-AAAAA-AAAAAA-AAAAAA-AAAAAA at 172.16.0.125:22000-192.168.1.114:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256
2023-02-10 22:51:16 Device AAAAAA-AAAAA-AAAAAA-AAAAAA-AAAAAA client is "syncthing v1.23.1" named "System-A" at 172.16.0.125:22000-192.168.1.114:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256
2023-02-10 22:53:05 Connection to AAAAAA-AAAAA-AAAAAA-AAAAAA-AAAAAA at 172.16.0.125:22000-192.168.1.114:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256 closed: reading length: EOF
2023-02-10 22:53:05 Established secure connection to AAAAAA-AAAAA-AAAAAA-AAAAAA-AAAAAA at 172.16.0.125:22000-192.168.1.114:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256
2023-02-10 22:53:05 Device AAAAAA-AAAAA-AAAAAA-AAAAAA-AAAAAA client is "syncthing v1.23.1" named "System-A" at 172.16.0.125:22000-192.168.1.114:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256
2023-02-10 22:54:54 Connection to AAAAAA-AAAAA-AAAAAA-AAAAAA-AAAAAA at 172.16.0.125:22000-192.168.1.114:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256 closed: writing message: write tcp 172.16.0.125:22000->192.168.1.114:22000: write: connection reset by peer
2023-02-10 22:54:54 Established secure connection to AAAAAA-AAAAA-AAAAAA-AAAAAA-AAAAAA at 172.16.0.125:22000-192.168.1.114:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256
2023-02-10 22:54:54 Device AAAAAA-AAAAA-AAAAAA-AAAAAA-AAAAAA client is "syncthing v1.23.1" named "System-A" at 172.16.0.125:22000-192.168.1.114:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256
2023-02-10 22:54:54 Puller (folder "Share" (bbbb-bbbb), item "XXXX.zip"): syncing: finishing: pull: connection closed
2023-02-10 22:54:54 "Share" (bbbb-bbbb): Failed to sync 1 items
2023-02-10 22:54:54 Folder "Share" (bbbb-bbbb) isn't making sync progress - retrying in 12m8s.
2023-02-10 22:56:43 Connection to AAAAAA-AAAAA-AAAAAA-AAAAAA-AAAAAA at 172.16.0.125:22000-192.168.1.114:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256 closed: writing message: write tcp 172.16.0.125:22000->192.168.1.114:22000: write: connection reset by peer
2023-02-10 22:56:43 Established secure connection to AAAAAA-AAAAA-AAAAAA-AAAAAA-AAAAAA at 172.16.0.125:22000-192.168.1.114:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256
2023-02-10 22:56:43 Device AAAAAA-AAAAA-AAAAAA-AAAAAA-AAAAAA client is "syncthing v1.23.1" named "System-A" at 172.16.0.125:22000-192.168.1.114:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256
2023-02-10 22:58:32 Connection to AAAAAA-AAAAA-AAAAAA-AAAAAA-AAAAAA at 172.16.0.125:22000-192.168.1.114:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256 closed: writing message: write tcp 172.16.0.125:22000->192.168.1.114:22000: write: connection reset by peer
2023-02-10 22:58:32 Puller (folder "Share" (bbbb-bbbb), item "XXXXX.zip"): syncing: finishing: pull: connection closed
2023-02-10 22:58:32 "Share" (bbbb-bbbb): Failed to sync 1 items
2023-02-10 22:58:32 Folder "Share" (bbbb-bbbb) isn't making sync progress - retrying in 4m38s.
2023-02-10 22:58:32 Established secure connection to AAAAAA-AAAAA-AAAAAA-AAAAAA-AAAAAA at 172.16.0.125:22000-192.168.1.114:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256
2023-02-10 22:58:32 Device AAAAAA-AAAAA-AAAAAA-AAAAAA-AAAAAA client is "syncthing v1.23.1" named "System-A" at 172.16.0.125:22000-192.168.1.114:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256
Windows
2023-02-10 14:49:23 My ID: AAAAAAA-AAAAAAA-AAAAAAA-AAAAAAA-AAAAAAA
2023-02-10 14:49:24 Single thread SHA256 performance is 1831 MB/s using minio/sha256-simd (486 MB/s using crypto/sha256).
2023-02-10 14:49:25 Hashing performance is 1182.11 MB/s
2023-02-10 14:49:25 Overall send rate is unlimited, receive rate is unlimited
2023-02-10 14:49:25 TCP listener (192.168.1.114:22000) starting
2023-02-10 14:49:25 Ready to synchronize "Share C" (C) (sendonly)
2023-02-10 14:49:25 QUIC listener (192.168.1.114:22000) starting
2023-02-10 14:49:25 Ready to synchronize "Share A" (A) (sendonly)
2023-02-10 14:49:25 Ready to synchronize "Share B" (B) (sendreceive)
2023-02-10 14:49:25 GUI and API listening on 192.168.94.114:8384
2023-02-10 14:49:25 ...
2023-02-10 14:49:25 Access the GUI via the following URL: https://192.168.94.114:8384/
2023-02-10 14:49:25 Ready to synchronize "Share E" (E) (sendreceive)
2023-02-10 14:49:25 My name is "Windows-Server"
2023-02-10 14:49:25 Device BBBBBBBB-BBBBBBBB-BBBBBBBB-BBBBBBBB is "TrueNAS" at [dynamic]
2023-02-10 14:49:25 Ready to synchronize "Share D" (D) (sendonly)
2023-02-10 14:49:28 Completed initial scan of sendreceive folder "Share E" (E)
2023-02-10 14:49:39 Completed initial scan of sendreceive folder "Share B" (B)
2023-02-10 14:49:47 Completed initial scan of sendonly folder "Share D" (D)
2023-02-10 14:51:16 Established secure connection to BBBBBBBB-BBBBBBBB-BBBBBBBB-BBBBBBBB at 192.168.1.114:22000-192.168.1.130:7692/tcp-server/TLS1.3-TLS_AES_128_GCM_SHA256
2023-02-10 14:51:16 Device BBBBBBBB-BBBBBBBB-BBBBBBBB-BBBBBBBB client is "syncthing v1.23.0" named "TrueNAS" at 192.168.1.114:22000-192.168.1.130:7692/tcp-server/TLS1.3-TLS_AES_128_GCM_SHA256
2023-02-10 14:51:53 Completed initial scan of sendonly folder "Share C" (C)
2023-02-10 14:53:05 Connection to BBBBBBBB-BBBBBBBB-BBBBBBBB-BBBBBBBB at 192.168.1.114:22000-192.168.1.130:7692/tcp-server/TLS1.3-TLS_AES_128_GCM_SHA256 closed: reading message: read tcp 192.168.1.114:22000->192.168.1.130:7692: wsarecv: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2023-02-10 14:53:05 Established secure connection to BBBBBBBB-BBBBBBBB-BBBBBBBB-BBBBBBBB at 192.168.1.114:22000-192.168.1.130:7692/tcp-server/TLS1.3-TLS_AES_128_GCM_SHA256
2023-02-10 14:53:05 Device BBBBBBBB-BBBBBBBB-BBBBBBBB-BBBBBBBB client is "syncthing v1.23.0" named "TrueNAS" at 192.168.1.114:22000-192.168.1.130:7692/tcp-server/TLS1.3-TLS_AES_128_GCM_SHA256
2023-02-10 14:54:54 Connection to BBBBBBBB-BBBBBBBB-BBBBBBBB-BBBBBBBB at 192.168.1.114:22000-192.168.1.130:7692/tcp-server/TLS1.3-TLS_AES_128_GCM_SHA256 closed: reading message: read tcp 192.168.1.114:22000->192.168.1.130:7692: wsarecv: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2023-02-10 14:54:54 Established secure connection to BBBBBBBB-BBBBBBBB-BBBBBBBB-BBBBBBBB at 192.168.1.114:22000-192.168.1.130:7692/tcp-server/TLS1.3-TLS_AES_128_GCM_SHA256
2023-02-10 14:54:54 Device BBBBBBBB-BBBBBBBB-BBBBBBBB-BBBBBBBB client is "syncthing v1.23.0" named "TrueNAS" at 192.168.1.114:22000-192.168.1.130:7692/tcp-server/TLS1.3-TLS_AES_128_GCM_SHA256
2023-02-10 14:56:43 Connection to BBBBBBBB-BBBBBBBB-BBBBBBBB-BBBBBBBB at 192.168.1.114:22000-192.168.1.130:7692/tcp-server/TLS1.3-TLS_AES_128_GCM_SHA256 closed: reading message: read tcp 192.168.1.114:22000->192.168.1.130:7692: wsarecv: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2023-02-10 14:56:43 Established secure connection to BBBBBBBB-BBBBBBBB-BBBBBBBB-BBBBBBBB at 192.168.1.114:22000-192.168.1.130:7692/tcp-server/TLS1.3-TLS_AES_128_GCM_SHA256
2023-02-10 14:56:43 Device BBBBBBBB-BBBBBBBB-BBBBBBBB-BBBBBBBB client is "syncthing v1.23.0" named "TrueNAS" at 192.168.1.114:22000-192.168.1.130:7692/tcp-server/TLS1.3-TLS_AES_128_GCM_SHA256
2023-02-10 14:58:32 Connection to BBBBBBBB-BBBBBBBB-BBBBBBBB-BBBBBBBB at 192.168.1.114:22000-192.168.1.130:7692/tcp-server/TLS1.3-TLS_AES_128_GCM_SHA256 closed: reading message: read tcp 192.168.1.114:22000->192.168.1.130:7692: wsarecv: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2023-02-10 14:58:32 Established secure connection to BBBBBBBB-BBBBBBBB-BBBBBBBB-BBBBBBBB at 192.168.1.114:22000-192.168.1.130:7692/tcp-server/TLS1.3-TLS_AES_128_GCM_SHA256
2023-02-10 14:58:32 Device BBBBBBBB-BBBBBBBB-BBBBBBBB-BBBBBBBB client is "syncthing v1.23.0" named "TrueNAS" at 192.168.1.114:22000-192.168.1.130:7692/tcp-server/TLS1.3-TLS_AES_128_GCM_SHA256
2023-02-10 14:59:36 Connection to BBBBBBBB-BBBBBBBB-BBBBBBBB-BBBBBBBB at 192.168.1.114:22000-192.168.1.130:7692/tcp-server/TLS1.3-TLS_AES_128_GCM_SHA256 closed: reading message: read tcp 192.168.1.114:22000->192.168.1.130:7692: wsarecv: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2023-02-10 14:59:36 Established secure connection to BBBBBBBB-BBBBBBBB-BBBBBBBB-BBBBBBBB at 192.168.1.114:22000-192.168.1.130:7692/tcp-server/TLS1.3-TLS_AES_128_GCM_SHA256
2023-02-10 14:59:36 Device BBBBBBBB-BBBBBBBB-BBBBBBBB-BBBBBBBB client is "syncthing v1.23.0" named "TrueNAS" at 192.168.1.114:22000-192.168.1.130:7692/tcp-server/TLS1.3-TLS_AES_128_GCM_SHA256
2023-02-10 15:01:25 Connection to BBBBBBBB-BBBBBBBB-BBBBBBBB-BBBBBBBB at 192.168.1.114:22000-192.168.1.130:7692/tcp-server/TLS1.3-TLS_AES_128_GCM_SHA256 closed: reading message: read tcp 192.168.1.114:22000->192.168.1.130:7692: wsarecv: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2023-02-10 15:01:25 Established secure connection to BBBBBBBB-BBBBBBBB-BBBBBBBB-BBBBBBBB at 192.168.1.114:22000-192.168.1.130:7692/tcp-server/TLS1.3-TLS_AES_128_GCM_SHA256
2023-02-10 15:01:25 Device BBBBBBBB-BBBBBBBB-BBBBBBBB-BBBBBBBB client is "syncthing v1.23.0" named "TrueNAS" at 192.168.1.114:22000-192.168.1.130:7692/tcp-server/TLS1.3-TLS_AES_128_GCM_SHA256
2023-02-10 15:02:28 Connection to BBBBBBBB-BBBBBBBB-BBBBBBBB-BBBBBBBB at 192.168.1.114:22000-192.168.1.130:7692/tcp-server/TLS1.3-TLS_AES_128_GCM_SHA256 closed: reading message: read tcp 192.168.1.114:22000->192.168.1.130:7692: wsarecv: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2023-02-10 15:02:29 Established secure connection to BBBBBBBB-BBBBBBBB-BBBBBBBB-BBBBBBBB at 192.168.1.114:22000-192.168.1.130:7692/tcp-server/TLS1.3-TLS_AES_128_GCM_SHA256
2023-02-10 15:02:29 Device BBBBBBBB-BBBBBBBB-BBBBBBBB-BBBBBBBB client is "syncthing v1.23.0" named "TrueNAS" at 192.168.1.114:22000-192.168.1.130:7692/tcp-server/TLS1.3-TLS_AES_128_GCM_SHA256
It’ll kinda randomly sneak through a few files at night here and there. But not really make much progress. Maybe 20MB or so.
I saw this thread about wsarecv timeouts.
But in my logs it looks like both sides are blaming the other for closing the connection.
