I am running a fresh install of Debian Bullseye, and after installing from the repository, I followed the instructions to enable upgrades via apt, https://apt.syncthing.net/
I got no errors and then got an ‘updates available’ message from the Debian system and w/ Synaptic attempted to install. The first attempt failed with the error
BlockquoteW: Failed to fetch https://apt.syncthing.net/dists/syncthing/stable/binary-amd64/syncthing-discosrv_1.18.6_amd64.deb Error reading from server - read (5: Input/output error) [IP: 82.196.13.137 443]
The second attempt I noticed on the progress bar that the first part of the file came in very fast, then the download rate slowed to a crawl before I got the error:
Blockquote W: Failed to fetch https://apt.syncthing.net/dists/syncthing/stable/binary-amd64/syncthing-discosrv_1.18.6_amd64.deb Connection timed out [IP: 82.196.13.137 443]
The third attempt seemed to succeed…
Not sure if this is something that needs fixing, but thought I should report it.
ex-Gooserider
