Transfered files not shown
SInce more than 30 minutes syncthing uses the whole upload of my internet connection. Syncthing shows that it is uploading but it does not show in which folder (I just changed some files and know which folder is it). System: v.11.7 Windows 7 x64
That fact that its using the network does not mean that it’s downloading stuff. It could be exchanging indexes.
Also, its uploading this case. We don’t show what you are uploading anywhere (as it makes no sense, the other peer might have asked only for a few blocks which does not translate to progress in any way).
The other node is out of sync, hence the download progress is shown there.
