Ton of connectings outside
Question is simple. Why does the Syncthing use tons of connections for outside? That is not local sync only? That’s just some part cycling for 1 minute. And that’s going to send packets outside without stopping.
88.151.34.95 88.151.34.95 5.44.251.102 8.134.200.134 8.210.231.232 14.102.99.222 15.204.184.94 23.82.125.190 23.94.10.235 23.94.37.77 23.94.63.173 23.94.182.38 23.94.243.66 23.95.225.105 23.133.204.121 23.137.254.205 23.171.9.5 23.171.9.237 23.184.48.113 31.41.249.107 31.56.7.32 31.57.224.200 31.58.214.31 31.129.35.63 31.130.138.67 31.148.99.151 35.172.134.179 37.186.18.11 37.187.131.168 37.220.86.71 37.221.65.85 37.221.66.248 38.7.145.71 38.43.93.33 38.134.40.118 45.9.2.178 45.9.168.16 45.10.244.109 45.10.247.7 45.13.38.114 45.41.205.31 45.41.206.37 45.80.139.19 45.82.80.116 45.86.153.241 45.124.64.14 45.132.245.205 45.137.201.27 45.143.11.173 45.150.238.208 45.150.238.224 45.157.177.104 46.17.44.43 46.29.239.89 46.38.237.104 46.175.27.130 46.226.106.79 49.13.12.165 51.178.73.236 51.254.44.49 57.128.183.172 57.129.129.140 59.126.151.163 60.205.120.247 61.51.84.140 63.243.250.173 64.235.43.104 64.235.61.19 67.219.102.254 69.12.83.36 69.42.220.127 69.109.232.200 70.36.96.115 74.64.65.202 75.166.189.84 76.147.218.83 77.33.45.132 77.90.35.161 77.91.127.103 77.110.112.69 77.238.158.167 77.247.127.24 78.28.69.19 79.117.46.28 79.136.5.160 79.139.59.141 79.158.132.2 81.94.156.61 82.64.77.142 82.65.107.217 82.65.178.50 82.155.70.14 83.138.55.188 84.33.244.100 84.50.8.28 84.203.75.220 84.247.166.127 85.93.9.119 85.95.149.238 85.120.81.153 85.155.228.84 85.155.228.88 85.191.83.185 85.195.207.47 85.208.208.25 85.215.36.124 85.215.128.246 85.215.176.70 86.42.193.214 87.106.101.86 87.121.38.34 88.141.85.59 88.151.117.218 88.151.197.209 88.212.32.226 88.216.153.39 89.58.60.208 89.162.10.70 89.168.98.188 91.98.93.131 91.107.213.38 91.217.81.195 91.236.248.56 92.112.125.26 92.118.170.145 92.118.190.17 92.118.190.56 93.176.166.154 94.16.106.154 94.156.180.112 94.177.160.155 94.232.40.105 95.217.127.209 96.44.141.44 100.71.210.19 102.208.216.157 102.216.253.63 103.73.66.125 103.95.112.122 103.167.235.45 103.167.235.55 103.180.244.195 103.192.177.165 103.254.63.29 104.194.77.215 104.200.72.29 107.173.10.7 107.174.88.234 107.175.158.204 109.122.18.82 109.205.214.149 109.234.34.190 116.203.118.184 116.203.216.214 120.29.217.52 128.79.114.113 129.151.161.43 129.153.55.44 129.154.227.170 130.185.235.40 134.195.89.121 136.61.115.65 140.238.215.179 140.245.243.59 141.14.215.107 141.95.19.155 141.105.130.172 142.132.179.255 143.47.178.89 144.217.79.218 145.79.148.242 147.139.194.123 148.113.197.239 148.135.63.122 151.80.43.167 151.242.242.44 151.252.180.206 152.53.116.253 152.53.227.155 152.67.108.225 152.70.65.247 152.70.81.172 152.70.120.138 154.23.255.138 154.26.209.9 155.4.62.206 155.94.236.151 157.20.104.178 157.137.232.77 158.101.231.105 158.247.244.249 160.22.79.21 160.250.111.11 161.132.45.145 162.250.188.40 162.254.84.113 163.227.128.146 165.140.203.13 166.88.160.157 167.235.150.20 167.235.247.6 167.253.66.183 170.168.15.12 170.168.100.24 170.239.86.217 172.93.128.175 172.105.199.155 176.9.17.157 176.9.99.214 176.32.33.99 176.124.199.66 176.150.172.155 176.214.167.99 178.25.32.119 178.208.92.79 178.254.30.134 180.149.44.55 182.52.65.120 182.52.65.242 185.8.166.21 185.17.255.77 185.23.80.92 185.36.142.200 185.69.161.122 185.75.242.50 185.104.176.238 185.116.236.48 185.116.238.245 185.139.7.68 185.156.177.239 185.183.161.145 185.207.125.201 185.219.167.182 185.223.207.151 185.231.100.108 185.242.107.224 185.245.83.206 188.119.191.45 188.155.253.178 188.245.51.91 191.96.11.148 191.254.122.35 192.3.130.86 192.71.166.93 192.227.155.172 193.22.147.133 193.111.30.62 193.142.58.156 193.142.59.7 193.142.147.196 193.150.22.84 193.233.246.52 193.233.247.73 194.26.27.18 194.32.107.141 194.38.20.170 194.58.68.66 194.87.106.106 194.118.229.144 194.226.139.122 195.58.49.175 195.133.62.114 195.201.222.131 195.219.124.44 198.46.190.144 202.73.4.201 204.57.31.170 204.111.36.115 204.216.210.243 207.58.173.215 209.38.89.52 210.16.120.200 212.51.129.54 212.132.119.171 212.227.199.189 213.165.32.95 216.126.234.177 216.232.222.168 217.182.197.227 218.236.76.26 220.134.160.116 1und1 . de aebc . com counterpath . com internetcalls . com miwifi . com sipgate . net voipstunt . com syncthing . net
That’s relay and STUN stuff, as always.
Syncthing probes relays for latency at startup, and keeps some on standby even if sync is only local at the moment.
Note that this behavior can be turned off (search the documentation or this forum; this question comes up from time to time)
Also note that while Syncthing CAN be used purely within the local network, it is basically not what it was designed to do (since that can/could be done in a somewhat secure and somehwat simple way using a number of tools already before Syncthing was born) Just writing this as a disclaimer for why that is not the default.
