Is there any way to enable TLS 1.2 on Syncthing UI? I didn’t see any configuration to change it.
I know file transfers are encrypted using TLS v1.2, but what about the UI?
UI does too.
Could you tell me how to configure it? I can’t seem to find documentation regarding this.
You don’t need to configure it - it’s enabled. You need a browser that supports it, which should be pretty much all of them.
Hmm, I’d also want to disable older versions of TLS. Hence, I’m asking for a way to configure it. Is that possible?
That is not possible, no.
Okay. Thanks a lot for the super fast replies! Really appreciate it
