Whenever I run tests on my system I get a panic. I am running go1.14beta1 and it’s not reproducible with go1.13.x. What’s weird is that on TC the go1.14 build passes just fine. This isn’t urgent being beta and all, but it involves the new db GC, so I thought I’d post in case someone can make sense of it:
panic: runtime error: unsafe pointer conversion
goroutine 226 [running]:
github.com/spaolacci/murmur3.(*digest128).bmix(0xc0000f87e0, 0xc000296481, 0x20, 0x2f, 0x0, 0x48, 0x58)
/media/ext4_data/Coding/go/pkg/mod/github.com/spaolacci/murmur3@v1.1.0/murmur128.go:67 +0xc0
github.com/spaolacci/murmur3.(*digest).Write(0xc0000f87e0, 0xc000296481, 0x20, 0x2f, 0xbf3004, 0xc0000f87e0, 0xc0000f87e0)
/media/ext4_data/Coding/go/pkg/mod/github.com/spaolacci/murmur3@v1.1.0/murmur.go:51 +0x127
github.com/willf/bloom.baseHashes(0xc000296481, 0x20, 0x2f, 0x0, 0x0, 0x0, 0x0)
/media/ext4_data/Coding/go/pkg/mod/github.com/willf/bloom@v2.0.3+incompatible/bloom.go:97 +0xb9
github.com/willf/bloom.(*BloomFilter).Test(0xc00000ee40, 0xc000296481, 0x20, 0x2f, 0x12ada80)
/media/ext4_data/Coding/go/pkg/mod/github.com/willf/bloom@v2.0.3+incompatible/bloom.go:183 +0x6b
github.com/syncthing/syncthing/lib/db.(*Lowlevel).gcBlocks(0xc000032550, 0x0, 0x0)
/media/ext4_data/Coding/go/src/github.com/syncthing/syncthing/lib/db/lowlevel.go:575 +0x4d4
github.com/syncthing/syncthing/lib/db.(*Lowlevel).gcRunner(0xc000032550)
/media/ext4_data/Coding/go/src/github.com/syncthing/syncthing/lib/db/lowlevel.go:488 +0x279
created by github.com/syncthing/syncthing/lib/db.NewLowlevel
/media/ext4_data/Coding/go/src/github.com/syncthing/syncthing/lib/db/lowlevel.go:65 +0x36a
FAIL github.com/syncthing/syncthing/lib/model 0.346s
