Hello
I want to know what is the minimum system requirements to operate with syncthing?, what is the memory amount to work with it
Thanks for your answer.
Hello
That depends on what you’re doing with it. According to https://data.syncthing.net memory usage is usually between 18 and 195 MiB.
Thanks for you answer, I have few clients (maybe 5 or 6) and I looking for this kind of solutions to share and back-up files.
