What is the minimum system requirements for FreeBSD to operate with syncthing (version 1.3.2)?
We don’t have defined minimum requirements. You can start Syncthing and run some experiments with maybe 100-200 megs of RAM, the rest depends on what you want to do with it.
ok, what is the earliest version of FreeBSD I can install Syncthing?
Go 1.13, which we build our binaries with, requires FreeBSD 11.2 and that may or may not carry on into Syncthing. I’m not sure. You can always compile with an older Go, though.
Many thanks!
