Hi there ! I would like to know if there is a number of nodes limit with SyncThing. I would like to use it for synchronizing files from one server to more than 200 servers. Have you some feedbacks regarding this type of configuration ? Regards, Jerome
It has been asked a few times, you should search the forum.
The quick answer is, there is no coded limit but more resources are required for every connected device. More resources are require the more files are in a share and slightly more resources are required the larger the share is.
FYI, https://data.syncthing.net shows the largest reported cluster as 211 devices.
I wouldn’t suggest you connect all devices to ask other devices but someone has 211 working.
Here’s an interesting topology which was posted recently.
Wow, very interesting ! Thanks.
