Synthing stops manually on Synology NAS
Hi all,
Since a couple of years I use Syncthing to sync between Android phone and tablets, a Windows computer and another NAS (DS920+). The heart of the system is a rather old DS214Play. It worked fine and configuring it was quite straightforward.
Early february I converted to the SQLite database which took about 24 hours! On the DS920+ it took about 20 minutes! It worked fine again after conversion.
Since march the 3rd it stopped working and syncthing is (according to the DS214Play) manually stopped. All the other machines work fine.
I tried to reinstall Synthing first without deleting data, but eventually did a clean reinstall risking the 24hours building of the database again. The result is the same: Immediately after starting Syncthing it stops with the same message: stopped manually. (Dutch: Handmatig gestopt)
The latest build of syncthing in the SynoCommunity is 2.0.13-33. The latest version of DSM for a DS214Play is Version: 7.1.1-42962 Update 9
After a long search I found the logfile (syncthing.log) on the NAS. It is listed here. If I restart the package in the Synology package manager, only the 2 bottom lines are repeated without any further clues.
I tried to find a similar problem here on the forum but that was not succesfull,
I hope to get some clues on how to solve this problem other than replacing the old NAS, Thanks in advance!!
Regards, Hans
This is a known issue (please see https://github.com/syncthing/syncthing/issues/10587). The problem is specific to Synology and you need to downgrade if you want to continue using Syncthing for now.
I’ve also removed the log from your post, because it’s not needed considering the already known culprit, and it was posted in a way that it was unreadable anyhow :sweat_smile:.
My problem is solved with the above information. Indeed I had exactly the problem which was described in the issue provided. Since I am a linux novice it took me quite a selfstudy SSH and CLI to get things done or figure out what is meant, but finally I succeeded!
Thanks!
Hans
