Synology softwares vs syncthing ?
Been using syncthing for years
Just bought some synology back up drive as an off-site backup
For those who went through the process, should I use synology softwares or syncthing on the synology drive ?
I installed syncthing but was wondering which would be better.
Pros/Cons ?
I recommend that you think about what you want to achieve. You wrote that you want “off-site backup” and this is a Syncthing forum.
As you already know, Syncthing is a file synchronization tool which will synchronize one or more folders on two or more devices. So in the event of accidental or malicious deletes/edits on one device, your synchronized copies on other devices will also be updated. This is why the synchronized copies can not be regarded as backups.
Admittedly, Syncthing has a versioning feature which can be seen as a “poor man’s backup”, but for it to be effective you must enable it on a device which is never used in your day-to-day activities.
Conclusion: I think you should use a dedicated backup program instead. Maybe restic.
Tks
I intend to have regular snapshot of my backup. So if something happen, I can revert to some older snapshot… Go back in time
I just need now to decide if for that off-site backup, if I will make all my device sync through syncthing to the SYNOLOGY device or simply use the SYNOLOGY app on each of my device
And continue using syncthing between my 3 pcs, mobile phone etc
In the restic forum I recently wrote about this. 3-2-1 strategy for laptops and desktops? - #2 by martinleben - Getting Help - restic forum
I do not use Synology, but hopefully you will find it useful anyway. :slight_smile: If not, then someone with Synology experience will hopefully be able to offer more specific advice.
tks ! much appreciated
for now I was syncthing everything (almost) between several PCs and my phone
Could access everything from any device.
If my house burn with all the devices, I would be in trouble LOL
To keep it simple, I will probably continue using Syncthing between devices and add to each device a new sync config to the SYNOLOGY drive
Would end up with everything is everywhere, using syncthing, and also on the synology, using syncthing
JF or I could simply sync one of the device with the SYNOLOGY drive, using the SYNOLOGY product LOL (app ) …Will see
As long as you are aware about the difference between “backup” and “synchronized copy” and implement accordingly, you should be fine. Good luck!
