murchu
February 2, 2022, 11:27pm
#1
Just registered to report that the package update above appears to have wiped the Syncthing config (other than the device ID) on my DS920+ running DSM7 and I have to recreate the shares etc. A word of caution to other users.
EDIT: Just to clarify, Syncthing’s internal update mechanism had updated the binary to version 1.19.0 without any issue but a subsequent package update published by SynoCommunity and available from within DSM’s package center caused the problem.
dingo
February 3, 2022, 3:04am
#2
I had the same thing happen. If you want to preserve your existing client sync configurations/relationships, DO NOT TAKE THIS PACKAGE UPDATE.
You already have the Syncthing code updated via its own autoupdate mechanism.
I urge the SynoCommunity to pull back this package. There is no warning about the extensive damage it does and reconfiguration that will be required. Especially concerning for people with lots of different folders sync’d.
zendnez
February 3, 2022, 4:00am
#3
This hit me, too. Identical circumstances. Someone should take a look.
imsodin
(Simon)
February 3, 2022, 6:14am
#4
This is not the synocommunity - you should report to them asap. This topic might still helpful in reaching other Syncthing users on synology, but it is not the right place to report a bug and get it fixed, that would be here I guess: Issues · SynoCommunity/spksrc · GitHub
Jengo
February 3, 2022, 7:32am
#5
Same happened to me too!
All of the Syncthing configuration, nodes lost after upgrade to 1.19.0…
Synology DS218j
DSM 7.0.1.
When I ssh to the NAS two Syncthing process drives the NAS CPU at 100% (htop). When I stop Syncthing the load returns to minimal.
calmh
(Jakob Borg)
February 3, 2022, 7:57am
#6
Historically, @acolomb has had some involvement with the SynoCommunity package. Highlighting for awareness, just in case. But, what Simon says – do report in the appropriate places as well.
acolomb
(André Colomb)
February 3, 2022, 8:04am
#7
I’ll look into it ASAP. Hard for me to test on DSM 7 though, as my devices are all still on DSM 6.2.
Issue reported on SynoCommunity: https://github.com/SynoCommunity/spksrc/issues/5116
acolomb
(André Colomb)
February 3, 2022, 8:06am
#8
Did you hit a “repair package” button or similar anytime? Any chance your problems might be related to this:
opened 01:13PM - 27 Sep 21 UTC
### Setup
_Package Name:_ Syncthing
_Package Version:_ 1.17.0-22
_NAS Model… :_ DS2415+
_NAS Architecture:_ INTEL Atom C2538
_DSM version:_ 7.0.1-42214
### Expected behavior
Syncthing setup files should be preserved
### Actual behavior
Syncthing setup files were apparently deleted...
I've not had any such problems before (and I have successfully upgraded another Synology NAS with the same configuration), but today I performed the following sequence of actions:
- Ensured the Syncthing package was up to date;
- Upgraded from DSM 6.2.4 to 7.0.1;
- Repaired the Syncthing package after the DSM upgrade.
On launching Syncthing after this, I was greeted with a default setup.
Looking in `/volume1/@appstore/syncthing/var` (the DSM6 location), I can only see new `config.xml` and `options.conf` files - the `index-v0.14.0.db` folder etc are entirely missing.
Looking in `/volume1/@appdata/syncthing/var` (the DSM7 location), I can see a full complement of setup files - but these have been generated anew.
#### Package log
Looking at the package log, I can't see anything that differs from previous upgrade entries - though I am confused by `Begin /bin/rm -rf /volume1/@appstore/syncthing` - I can't see how the app data is preserved through this...
2021/09/27 08:41:45 install syncthing 1.17.0-22 Begin start-stop-status stop
2021/09/27 08:41:48 install syncthing 1.17.0-22 End start-stop-status stop ret=[0]
2021/09/27 09:09:45 (system) trigger syncthing 1.17.0-22 Begin start-stop-status stop
2021/09/27 09:09:46 (system) trigger syncthing 1.17.0-22 End start-stop-status stop ret=[0]
2021/09/27 09:16:21 upgrade syncthing 1.17.0-22 Begin preupgrade
2021/09/27 09:16:21 ===> Step preupgrade. USER=sc-syncthing GROUP=sc-syncthing SHARE_PATH=
2021/09/27 09:16:21 upgrade syncthing 1.17.0-22 End preupgrade ret=[0]
2021/09/27 09:16:21 upgrade syncthing 1.17.0-22 Begin preuninst
2021/09/27 09:16:21 ===> Step preuninst. USER=syncthing GROUP=sc-syncthing SHARE_PATH=
2021/09/27 09:16:21 upgrade syncthing 1.17.0-22 End preuninst ret=[0]
2021/09/27 09:16:22 upgrade syncthing 1.17.0-22 Begin /bin/rm -rf /volume1/@appstore/syncthing
2021/09/27 09:19:13 upgrade syncthing 1.17.0-22 End /bin/rm -rf /volume1/@appstore/syncthing ret=[0]
2021/09/27 09:19:13 upgrade syncthing 1.17.0-22 Begin postuninst
2021/09/27 09:19:13 ===> Step postuninst. USER=syncthing GROUP=sc-syncthing SHARE_PATH=
2021/09/27 09:19:13 upgrade syncthing 1.17.0-22 End postuninst ret=[0]
2021/09/27 09:19:13 upgrade syncthing 1.17.0-22 Begin preinst
2021/09/27 09:19:13 ===> Step preinst. USER=sc-syncthing GROUP=sc-syncthing SHARE_PATH=
2021/09/27 09:19:13 upgrade syncthing 1.17.0-22 End preinst ret=[0]
2021/09/27 09:19:13 upgrade syncthing 1.17.0-22 Begin /bin/mkdir -p /volume1/@appstore/syncthing
2021/09/27 09:19:13 upgrade syncthing 1.17.0-22 End /bin/mkdir -p /volume1/@appstore/syncthing ret=[0]
2021/09/27 09:19:13 upgrade syncthing 1.17.0-22 Begin /bin/rm -rf /volume1/@appstore/syncthing
2021/09/27 09:19:13 upgrade syncthing 1.17.0-22 Begin /bin/mv -f /volume1/@tmp/pkginstall/extract.dgMWMl/package /volume1/@appstore/syncthing
2021/09/27 09:19:13 upgrade syncthing 1.17.0-22 End /bin/mv -f /volume1/@tmp/pkginstall/extract.dgMWMl/package /volume1/@appstore/syncthing ret=[0]
2021/09/27 09:19:13 upgrade syncthing 1.17.0-22 Begin /bin/rm -rf /var/packages/syncthing
2021/09/27 09:19:14 upgrade syncthing 1.17.0-22 End /bin/rm -rf /var/packages/syncthing ret=[0]
2021/09/27 09:19:14 upgrade syncthing 1.17.0-22 Begin /bin/mkdir -p /var/packages/syncthing
2021/09/27 09:19:14 upgrade syncthing 1.17.0-22 End /bin/mkdir -p /var/packages/syncthing ret=[0]
2021/09/27 09:19:14 upgrade syncthing 1.17.0-22 Begin /bin/touch /var/packages/syncthing/installing
2021/09/27 09:19:14 upgrade syncthing 1.17.0-22 End /bin/touch /var/packages/syncthing/installing ret=[0]
2021/09/27 09:19:14 upgrade syncthing 1.17.0-22 Begin /bin/mv -f /volume1/@tmp/pkginstall/extract.dgMWMl/INFO /var/packages/syncthing/INFO
2021/09/27 09:19:14 upgrade syncthing 1.17.0-22 End /bin/mv -f /volume1/@tmp/pkginstall/extract.dgMWMl/INFO /var/packages/syncthing/INFO ret=[0]
2021/09/27 09:19:14 upgrade syncthing 1.17.0-22 Begin /bin/rm -rf /var/packages/syncthing/scripts
2021/09/27 09:19:14 upgrade syncthing 1.17.0-22 End /bin/rm -rf /var/packages/syncthing/scripts ret=[0]
2021/09/27 09:19:14 upgrade syncthing 1.17.0-22 Begin /bin/mv -f /volume1/@tmp/pkginstall/extract.dgMWMl/scripts /var/packages/syncthing/scripts
2021/09/27 09:19:14 upgrade syncthing 1.17.0-22 End /bin/mv -f /volume1/@tmp/pkginstall/extract.dgMWMl/scripts /var/packages/syncthing/scripts ret=[0]
2021/09/27 09:19:14 upgrade syncthing 1.17.0-22 Begin /bin/rm -rf /var/packages/syncthing/WIZARD_UIFILES
2021/09/27 09:19:14 upgrade syncthing 1.17.0-22 End /bin/rm -rf /var/packages/syncthing/WIZARD_UIFILES ret=[0]
2021/09/27 09:19:14 upgrade syncthing 1.17.0-22 Begin /bin/mv -f /volume1/@tmp/pkginstall/extract.dgMWMl/WIZARD_UIFILES /var/packages/syncthing/WIZARD_UIFILES
2021/09/27 09:19:14 upgrade syncthing 1.17.0-22 End /bin/mv -f /volume1/@tmp/pkginstall/extract.dgMWMl/WIZARD_UIFILES /var/packages/syncthing/WIZARD_UIFILES ret=[0]
2021/09/27 09:19:14 upgrade syncthing 1.17.0-22 Begin /bin/rm -rf /var/packages/syncthing/conf
2021/09/27 09:19:14 upgrade syncthing 1.17.0-22 End /bin/rm -rf /var/packages/syncthing/conf ret=[0]
2021/09/27 09:19:14 upgrade syncthing 1.17.0-22 Begin /bin/mv -f /volume1/@tmp/pkginstall/extract.dgMWMl/conf /var/packages/syncthing/conf
2021/09/27 09:19:14 upgrade syncthing 1.17.0-22 End /bin/mv -f /volume1/@tmp/pkginstall/extract.dgMWMl/conf /var/packages/syncthing/conf ret=[0]
2021/09/27 09:19:16 upgrade syncthing 1.17.0-22 Begin postinst
2021/09/27 09:19:16 ===> Step postinst. USER=sc-syncthing GROUP=sc-syncthing SHARE_PATH=
2021/09/27 09:19:16 upgrade syncthing 1.17.0-22 End postinst ret=[0]
2021/09/27 09:19:16 upgrade syncthing 1.17.0-22 Begin postupgrade
2021/09/27 09:19:16 ===> Step postupgrade. USER=sc-syncthing GROUP=sc-syncthing SHARE_PATH=
2021/09/27 09:19:16 upgrade syncthing 1.17.0-22 End postupgrade ret=[0]
2021/09/27 09:19:16 upgrade syncthing 1.17.0-22 Begin start-stop-status start
2021/09/27 09:19:16 upgrade syncthing 1.17.0-22 End start-stop-status start ret=[0]
This isn't a massive problem for me - I can re-set the config manually - but I wouldn't want someone else to fall foul of an unexpected problem here.
And many thanks for the DSM7-compatible release otherwise - great work! :-)
d3rm4tz3
(Matze Ru)
February 3, 2022, 8:18am
#9
Same here, after using the package center update, my config was gone. I took a while until synchting was up and running again. But i still have to reconfig all my settings.
@acolomb i never used the repair package button.
Best regards
m4tz3
acolomb
(André Colomb)
February 3, 2022, 10:09am
#10
@murchu , @dingo , @zendnez , @Jengo , @d3rm4tz3 would any of you happen to be confident enough to handle manual backup / restoring of the Syncthing config folder on the DS?
I could provide preview packages when we have a fix ready for testing. But would strongly advise to make a proper config backup first before trying a downgrade / upgrade again with the testing package. One important thing would be to stop the Syncthing service before making such a backup.
murchu
February 3, 2022, 11:19am
#11
Sure, no problem. I haven’t reconfigured it yet but will do shortly, at least in part. Is it just the config.xml file in /@appdata /Syncthing needs to be backed up?
PS re ‘repair package’: for me that was required post-update to DSM 7 but did not result in any loss of data at that time.
d3rm4tz3
(Matze Ru)
February 3, 2022, 1:50pm
#12
I have now reconfigured my Syncthing. The folders will now be scanned again.
How can I help? Do I also only have to back up the config.xml?
rivageeza
(riva)
February 3, 2022, 3:45pm
#13
Same happened to me. I thought I would uninstall and then re-install just to clear out everything 100%, but now the package has been removed so I’m stuck without a working setup.
hgy59
(hgy59)
February 3, 2022, 4:04pm
#14
Version 1.19.9-24 is now removed in the synocommunity package repository.
A fix is in progress at https://github.com/SynoCommunity/spksrc/pull/5117 .
acolomb
(André Colomb)
February 3, 2022, 4:35pm
#15
@rivageeza Meanwhile you could just install the older version available from SynoCommunity as a manual download.
acolomb
(André Colomb)
February 3, 2022, 4:39pm
#16
Regarding manual backups, you basically need most of the files from /var/packages/syncthing/var/
(root access required ). The most important ones are:
config.xml
cert.pem
key.pem
as well as the index-v0.14.0.db
folder with the database.
Definitely STOP the Syncthing service before making the backup! Just to be sure, I always back up the whole folder with approximately these contents:
-rw-rw-r-- 1 sc-syncthing syncthing 619 Jan 1 2019 cert.pem
-rw------- 1 sc-syncthing syncthing 66507 Jan 15 11:57 config.xml
-rw------- 1 sc-syncthing syncthing 363 Jan 15 11:54 csrftokens.txt
lrwxrwxrwx 1 sc-syncthing syncthing 61 Feb 3 09:42 https-cert.pem -> /usr/local/etc/certificate/syncthing/syncthing_webui/cert.pem
lrwxrwxrwx 1 sc-syncthing syncthing 64 Feb 3 09:42 https-key.pem -> /usr/local/etc/certificate/syncthing/syncthing_webui/privkey.pem
drwxr-xr-x 2 sc-syncthing syncthing 4096 Feb 3 14:15 index-v0.14.0.db
-rw------- 1 sc-syncthing syncthing 288 Jan 1 2019 key.pem
-rw-r--r-- 1 sc-syncthing syncthing 261 Aug 2 2019 options.conf
-rw-r--r-- 1 sc-syncthing syncthing 832 Aug 2 2020 syncthing_install.log
-rw-r--r-- 1 sc-syncthing syncthing 101594 Feb 3 17:38 syncthing.log
-rw-r--r-- 1 sc-syncthing syncthing 6 Feb 3 09:42 syncthing.pid
hgy59
(hgy59)
February 3, 2022, 4:56pm
#17
with 1.19.0-24 only options.conf
and config.xml
were overwritten with the former default files contained in the spk file of the downloaded package.
A workaround would have been to delete the /var/packages/syncthing/target/var
folder (NOT /var/packages/syncthing/var
!!!) before the update, but as 1.19.0-24 is not available for download anymore, you have to wait for 1.19.0-25 anyway.
acolomb
(André Colomb)
February 3, 2022, 5:19pm
#18
By the way, welcome @hgy59 to our community forum
And thank you for picking up work on this so quickly. We have a fix imminent and I suppose a new version might be published today. Without your help, I definitely could not have handled this problem within one day of the initial report!
hgy59
(hgy59)
February 3, 2022, 8:21pm
#20
Syncthing v1.19.0-25 is now uploaded to the synocommunity package center (and available for manual download and installation) and will appear in the DSM package center of the diskstations within 48h.
