syncthing zombie process
I had an instance of syncthing running but (don’t know what happened) it crashed, killed it and is now a zombie process owned by PID 1. When I try to run syncthing in the same machine it gets stuck
[start] 2023/09/04 10:10:35 INFO: syncthing v1.23.7 "Fermium Flea" (go1.20.7 linux-amd64) builder@github.syncthing.net 2023-07-31 03:45:37 UTC
and if I try to run in another machine in the same cluster sharing the same disk space I get (a trials of)
[start] 2023/09/04 10:03:46 INFO: syncthing v1.23.7 "Fermium Flea" (go1.20.7 linux-amd64) builder@github.syncthing.net 2023-07-31 03:45:37 UTC
[start] 2023/09/04 10:03:47 INFO: Using large-database tuning
[start] 2023/09/04 10:03:47 WARNING: Error opening database: resource temporarily unavailable (is another instance of Syncthing running?)
[monitor] 2023/09/04 10:03:47 INFO: Syncthing exited: exit status 1
I’m not the administrator of the machines so I cannot reboot the first one. Is there anything I can do? Maybe delete a lock file or something like that? Would that be safe?
Cheers.
How do you know its a zombie? Sounds like the monitor process got killed/died and it got orphaned.
I assume you tried killing it?
Yes, I tried killing it. Right now what I have in this machine is
meaning all of the syncthing processes are owned by the init process and I have no way of getting rid of them.
State D means means it’s stuck waiting on I/O, maybe a dead NFS filesystem or a hardware problem if it’s not temporary (busy disks).
Yes, it could be some NFS/hardware problem since dmesg shows all kinds of weird errors and warnings.
So, is there any “workaround” to the state D/Z processes? (unfortunately, reboot is not an option :face_with_diagonal_mouth:)
There is no workaround, this is a kernel/system issue.
I meant in terms of “telling” syncthing to ignore that there is another (sleeping/dead/zombie) instance running. Maybe deleting some .lock file or something of the sorts…
Don’t do that, lest you invite a zombie apocalypse if/when those processes get unstuck and return from the dead. The database lock is there for good reason. Instead complain to your system administrator.
OK, it makes sense :grinning:
Thanks!!
