Syncthing won't load after OnePlus 6 upgrade to Android 10
As the title reads.
Syncthing hangs on the “loading GUI” prompt. I’ve checked and granted full permissions to the app.
Anyone have any suggestions for a fix?
Thanks!
No, it’s AArch64.
Sorry, can you break this down for a layperson? I googled that command and it appears I need some to install some debugging software on my PC?
Happy to send error logs, just not sure how to do it!
Thank you!
Great, thank you! Here is the log.
logcat.txt (803.0 KB)
Yes, both. No luck!
Sorry, come again?
Thanks!
Just installed it, so far so good. Adding the directories - hoping it won’t do a full resync (and instead just sync any recent unmirrored changes).
Will follow-up in a bit to confirm if this is resolved or not.
I think this is resolved. Thank you!
