Syncthing v1.7.0, v1.7.1
v1.7.0
This release performs a database migration to optimize for clusters with many devices.
Bugfixes
  • #6552: panic: Stop called more than once on … created by nat.Service
  • #6564: Closing an already removed connection causes GUI error message
  • #6646: Misleading error message when to be deleted dir contains receive-only changes
  • #6653: panic: nil pointer dereference in leveldb.(*DB).isClosed()
  • #6654: panic: runtime error: index out of range in processNeeded()
  • #6655: panic: nil pointer dereference in checkUpgrade()
  • #6679: QUIC listener is not added when default TCP port is unavailable
  • #6697: Malformed listen address causes hang on startup
  • #6706: Changing a folder in web UI removes introduced-by info
Enhancements
  • #1830: “Folder path missing” when folder path is a junction
  • #4703: Suggest setting up auth on initial startup
  • #5910: Add Badger database backend for testing and consideration
  • #6372: Reduce database size by optimizing version list storage
Other issues
  • #6608: Data race in Windows fs watcher tests
  • #6625: TestRequestRemoteRenameChanged is racy/flaky
v1.7.1
Hotfix for the “pull: not found” error.
Bugfixes
  • #6827: syncthing 1.6.1 -> 1.7.0 fails on “failed validating data”
This topic was automatically closed after 30 days. New replies are no longer allowed.
