v1.30.0
Syncthing 2 is coming
Syncthing version 1.x will soon be replaced by Syncthing version 2.x. Version 2 brings a new database format and various cleanups, but remains protocol compatible with Syncthing 1.
More detailed information about Syncthing 2 can be found in the release notes at Releases · syncthing/syncthing · GitHub.
This release is also available as:
APT repository: https://apt.syncthing.net/
Docker image:
docker.io/syncthing/syncthing:1.30.0orghcr.io/syncthing/syncthing:1.30.0({docker,ghcr}.io/syncthing/syncthing:1to follow just the major version)
What’s Changed
Fixes
- fix(protocol): avoid deadlock with concurrent connection start and close by @calmh in #10140
- fix(syncthing): avoid writing panic log to nil fd by @ardevd in #10154
Features
Other
- build: properly propagate build tags to Debian build by @calmh in #10144
- chore(protocol): don’t start connection routines a second time by @imsodin in #10146
- chore(protocol): only allow enc. password changes on cluster config by @imsodin in #10145
Full Changelog: Comparing v1.29.7...v1.30.0 · syncthing/syncthing · GitHub
