Syncthing v1.28.1 [contains security fix]
v1.28.1
Security
Version 1.28.0 added a bug where block request messages to untrusted devices would include the hash of the plaintext block being requested. This isn’t recorded anywhere on the untrusted device by a stock Syncthing, but a potentially modified/illicit Syncthing instance could in principle record the plaintext hashes of encrypted data, thus being able to draw some conclusions about the data being stored.
Bugfixes
  • #9400: Folder overlap not detected when using tilde
  • #9590: WebUI table column widths broken on iPhone 12 Pro Max and wider
  • #9686: Sync status stays at 'Syncing xx%" when remote device pauses the folder.
  • #9757: Firefox, dark theme: device ID is hard to read
  • #9775: Junctions as dirs doesn’t work anymore
  • #9776: Disabled checkbox panels don’t respect dark theme
  • #9783: gui: Address override not respected in fresh default config
  • #9821: panic: runtime error: index out of range [-1]
Enhancements
  • #9725: Ignoring symbolic links when syncing on android as well
This topic was automatically closed after 30 days. New replies are no longer allowed.
