Syncthing v1.22.2
v1.22.2
Bugfixes
  • #3744: Folders with custom icons not deletable on Windows
  • #8570: Incorrect rescan interval when add encrypted folder with watch for changes enabled
  • #8592: Newly added “connection type” icon and text in device info is slightly misaligned
  • #8630: Enabling rate limit drastically reduces network performance
  • #8654: Conflicts created on Android on files modified by other devices
  • #8657: Xattrs not properly applied to directories, causes rescan/resync loop
  • #8661: webgui complains about not set password in ldap mode
  • #8682: syncthing generate command writes the deviceId to stderr instead of stdout as INFO
Enhancements
  • #2771: Add mailto link to “Show ID” dialog, for sending device ID via email
  • #7703: Show if devices have not connected in a long time
  • #8638: Use healtcheck endpoint for docker
  • #8686: LAN detection via subnetmask
Other issues
  • #8601: Build fails due to setting xattrs that affect SELinux, “permission denied”
  • #8679: Bump quic-go
This topic was automatically closed after 30 days. New replies are no longer allowed.
