Syncthing v1.2.1
v1.2.1
Bugfixes
  • #5308: FreeBSD: Create new file does not generate a fs event.
  • #5801: panic: close of nil channel in relay client stop
  • #5803: Web UI shows confusing description on RC builds when upgrades are disabled
  • #5828: panic: Index update for not running folder
  • #5833: Paused folder shows filesystem watcher error
  • #5837: panic: runtime error: index out of range in recheckFile
  • #5849: Cannot concatenate external versioner template variables ("%FOLDER_PATH%/%FILE_PATH%")
  • #5880: panic: runtime error: invalid memory address or nil pointer dereference in loadIgnoreFile
Enhancements
  • #5811: Download progress of folders in the UI should update more frequently
Other issues
  • #5754: Support paging on jobQueue.Jobs
  • #5813: Potential bugs on old cores: using 64-bit functions sync/atomic
  • #5853: Inconsistent handling of empty folder path
Thanks to the team as always for your amazing work, amazing support and amazing tool - it has literally changed the way I work!
This topic was automatically closed after 30 days. New replies are no longer allowed.
