v1.18.0
Bugfixes
- #7708: irreversible Local Additions after re-adding the same folder as Receive Only
- #7731: Scan due to watcher can not found local change while modify file to empty
- #7733: TypeError: Cannot read property ‘urAccepted’ of undefined
- #7741: Out-of-sync state of zero-byte files is not reflected on peers
Enhancements
- #7700: Add rest endpoint(s) to dismiss pending folder/device invitations
- #7705: Accepting a receive encrypted folder share should prompt the user to input a password
- #7722: Database GC can block for a long time
- #7724: Ensure encryption to untrusted on new, trusted device on an existing folder
- #7742: Use defaults for missing fields on the config rest API
- #7743: Show discovery and listener status when not failed
tip to
) and keeping our data
safe!
