Syncthing v1.16.0 & v1.16.1
v1.16.0
This release adds untrusted / encrypted devices for public testing. It should still be considered beta / testing-only.
Bugfixes
  • #7026: panic: key not found when repairing DB
  • #7379: “Warning, this path is a subdirectory of an existing folder” does not appear when editing only folder label
  • #7533: Remote completion on untrusted devices is incorrect
  • #7548: Upgrading syncthing-relaysrv to 1.15.0 fails in post-installation
  • #7551: QUIC: failed to determine receive buffer size: doesn’t have a SyscallConn
  • #7557: Encrypted folder(s) on Windows reported as “Unexpected Objects”
  • #7568: panic: runtime error: slice bounds out of range [24:3]
  • #7584: Folder label missing from folder path when adding new folders
Enhancements
  • #109: Support for file encryption (e.g. non-trusted servers)
  • #3322: GUI “Out of sync” modal uses massive amounts of CPU in browser
  • #7520: Ask for confirmation before reverting/overriding a folder
FYI
Added 1.16.1 which fixes a Debian packaging bug; no other changes.
Congratulations to closing #109 !
A true milestone, thank you Syncthing community very much for all the effort, emotions, passion and dedication put into this!
This topic was automatically closed after 30 days. New replies are no longer allowed.
