v1.11.0
This release adds the sendFullIndexOnUpgrade option to control whether
all index data is resent when an upgrade is detected, equivalent to
starting Syncthing with --reset-deltas. This
(sendFullIndexOnUpgrade=true) used to be the behavior in previous
versions, but is mainly useful as a troubleshooting step and causes high
database churn. The new default is false.
Bugfixes
- #6994: “panic: filling Blocks: leveldb: snapshot released” on folder save
- #7002: “Syncing (NaN%, 0 B)” when syncing 0-byte files
- #7008: Filenames containing dots lead to a “The system cannot find the file specified” sync error
- #7021: Tests fail when building the Alpine pkg on aarch64
- #7034: Folders getting stuck in “Syncing” after a20c6ca after doing changes when folders are paused
- #7035: Devices Announcing LAN addresses even with AnnounceLANAddresses set to off/false
- #7036: Shutting Syncthing down while pushing files to multiple devices corrupts the database?
