v1.10.0
This release adds the config option announceLANAddresses to enable
(the default) or disable announcing private (RFC1918) LAN IP addresses
to global discovery.
Bugfixes
- #6880: fatal error: concurrent map iteration and map write
- #6917: Reconsider db check on upgrade
#6930: Can’t add new folder with versioning enabled,
Cleanup Intervalfield lacks default value - #6940: TypeError: Object doesn’t support property or method ‘startsWith’ in IE 11 / Windows 7
- #6943: Missing strings for translation
- #6961: Accounting issue with receive-only deleted files causing spurious 95% completion for remote devices
- #6968: Very slow scans on Windows in 1.9.0
- #6972: Deleting a folder containing a symlink results in a permanently out of sync on windows
- #6973: given name “~syncthing~xxx.tmp” differs from name in filesystem “~syncthing~XXX.tmp”
Enhancements
#4277: Announce internal and external address to the global discovery service,
encrypted(not actually encrypted) - #6734: Consider moving configuration to a proto contract
- #6928: Announce LAN addresses to global discovery
Other issues
- #5436: MultiArch for Docker
