v1.1.4
Bugfixes
- #4613: Progress emitter doesn’t start from config change if disabled at startup
- #5338: Version restore not possible with custom versioning path set
- #5421: WebGui: Locally Changed Items vanish when clicking 10|25|50
- #5578: Filesystem watcher error when watching disk root directory on Windows
- #5641: Syncthing gets stuck in a high CPU “Failed Files” state - Possibly a symlink issue?
- #5649: Checking block content on unexpected request results doesn’t work for the last block
- #5654: Incorrect file info passed as argument to delete existing dir/symlink
- #5704: Failure to fsync() files should not be fatal
Enhancements
- #1634: Use copy instead of rename for version folder on other file systems
- #4531: GUI folder/device status rows should handle longer values nicer
- #4586: Versioner file tagging is inconsistent
- #4631: In-GUI restoration should be possible from trashcan versioner
- #5419: File versioning across drives
- #5659: Old sync errors should not linger while retrying
