Syncthing v1.1.0
v1.1.0
Bugfixes
  • #5482: minHomeDiskFreePct is still present in fresh configs
  • #5493: Monitor bug: TERM signaling not passed to syncthing process
  • #5557: Hashing performance degradation when using large blocks
Enhancements
  • #5365: .desktop files: desktop-entry-lacks-keywords-entry
  • #5445: User/group ownership following parent dir
Other issues
  • #5077: TestWatchIgnore is flaky (OpenBSD (-current) Test failed)
  • #5246: TestParentDeletion fails on OpenBSD
  • #5311: Update prometheus/common/expfmt to pass tests on go1.11
  • #5454: build.go setup problems with gomodules
  • #5495: Dockerhub Docker builds fail continously
  • #5515: Missing string from Transifex
API Changes
  • Change #5479 introduces the new copyOwnershipFromParent folder configuration option. The default, false, matches the old behavior of not copying ownership information.
  • Since change #5405, large (variable size) blocks are enabled by default for newly created folders.
Thanks for the improvements!
Also
Return of the cli, although it’s a separate unshipped binary I guess.
Another great release and in particular I am pleased to see large blocks enabled by default. :slight_smile:
This topic was automatically closed after 30 days. New replies are no longer allowed.
