v0.14.46
Bugfixes
- #2571: Replacing a directory with a symlink or vice versa is buggy
- #4573: Inaccessible files during scan are marked as deleted
- #4616: Send only folder out of sync due to ignored items
- #4627: A file deleted from all nodes may exist in the “out of sync” list
- #4759: List of out of sync items from remote device is not displayed
- #4762: Fails to create folder root directory on Windows
- #4764: Env var for db metadata in help text differs from code
- #4778: Doesn’t connect when multiple remote devices are using the same relay
- #4799: Scan on absolute path creates incorrect absolute duplicate file infos
- #4806: Panic in FS watcher in FreeBSD 8.3
There is also a new relay server release:
- #4745: Relay server doesn’t make outgoing HTTPS requests from its bind address
