v0.14.43
Bugfixes
- #1845: Files on deduplicated NTFS volumes are ignored by scanner
- #4590: Path completion in new folder dialog does not work anymore
- #4593: Fd leak when temp file cannot be truncated
- #4605: Panic: runtime error related to KCP
Enhancements
- #2644: UI for debug levels and log access
- #4369: GUI should indicate which files are out of sync on remote devices
- #4400: Keep enough counters and state in the database to avoid initial database traversal
- #4515: Should understand “socks” in addition to “socks5” in proxy URLs
Other issues
- #4407: Contribute kcp-go changes/features and/or fix tests
- #4585: Update vendored github.com/minio/sha256-simd for AVX512 support
- #4615: Update vendored x/sys/unix for dragonfly
