This is a minor release recommended for all users.
This release includes “delta indexes”, a backwards compatible protocol
enhancement. Prior to delta indexes being implemented, full index information
was exchanged at every connection start. With delta indexes, only index
information that has changed since last contact is transferred. Delta indexes
are enabled automatically between 0.14.1+ devices.
#3440: Files that grow or shrink during scanning would result in conflicts or
inconsistent data after synchronization. This issue was introduced in 0.14.0.
One thing to note about the delta index addition is that it means that Syncthing now knows about files on other devices even when they are not connected. That means that if you had a file that should have been synced from a device, but you got disconnected, your local folder will display as “out of sync” even while disconnected. Previously it would look “up to date” as we wouldn’t know any better.
Upgrading now, delta indexes is a killer feature.
Thank you for listening to your users.
Hope now that inotify integration and next-gen ignores will make their way soon.
Keep up the good work
Wouldn’t a new release be better? I don’t think that linux distributions will package a development snapshot (they even need to be aware of this issue before) and the apt repo also only provides 0.14.1, right? And these are the users that probably rely on symlinks the most.
Also fixing a cluster would be much easier when syncthing’s upgrade mechanism is used and there is a new release.
