Hi, when starting my Win 10 PC Syncthing Tray gives me two errors, any idea how to fix them? Thanks.
Is Syncthing running? Check Task Manager for two Syncthing processes. If it is running, is the GUI available?
Yes, it is connecting and everything works fine
If Syncthing is working correctly, I don’t have a lot of ideas for you. Is a host based firewall blocking the local connection? Is antivirus doing something it shouldn’t? Does the user that owns the Syncthing Tray process have the correct rights? If none of those ideas bear fruit, all I have left is suggesting that you uninstall and reinstall Syncthing Tray.
Yes, everything is ok, firewall included. Well, this sucks. Thanks for the help though.
Go through your Syncthing Tray configuration in detail. And hopefully someone smarter than I am can help.
