Syncthing stuck at 95% 0B
I know this is another one of the having trouble syncing at 95% 0B I have tried what I have been able to find. Heres what I have done so far
  • Reinstalled Syncthing to ensure latest version
  • Set the folder to receive only on the system that is out of sync
  • Un-shared and re-shared the folder
  • Turned on ignore permissions(Never been a problem Before)
  • Run syncthing on both sides with --reset-deltas
Here are some screenshots Receiving Devices
Sending Device
This nnfs is a folder that exists and has content inside it(couple of small files)
Tap on the failed items line and it will say why it didn’t sync
The folder exists tho Like I have excluded directories to help handle state management for python and other projects but thats not all thats contained
Like for this folder heres exclusion patterns venv pycache
In the folder nnfs I have folders and then venv folder for my python virtual environment. But the other directories just contain regular files not excluded
I also just checked the folder on the recieving machine and Its all there minus the venv folder so the sync completed
