A couple of days ago all of our Windows Server machines(five of them in total) started having problems. They stop accepting connections on ports 22000 and 8384. Some times 8384 is open but unresponsive.
The affected servers are running Windows Server 2012 R2 and 2012 Essentials. All Windows servers that run Syncthing have this problem.
Our Linux servers are unaffected.
Restarting Syncthing fixes it, for a while. Then few hours later they stop responding.
They were running 1.11.1 when this began. I then updated them all to 1.12.0. no change.
They’ve been running for years without problems.
Explicitly setting Windows Firewall to permit ports 8484 and 22000 does nothing.
Anybody else have this problem? I was thinking a recent Windows update broke something. Nothing has changed on the servers otherwise.
Here is a piece of the log showing A startup that soon failed:
[start] 11:16:13 INFO: syncthing v1.12.0 "Fermium Flea" (go1.15.5 windows-amd64) teamcity@build.syncthing.net 2020-11-27 13:33:58 UTC
[LINRD] 11:16:14 INFO: My ID: XXXXXXX-YYYYYYYY-QQ4HUM5-E55QQAL-TEET6LP-YVMFBLH-JLVDSUJ-RBMNSQE
[LINRD] 11:16:15 INFO: Single thread SHA256 performance is 212 MB/s using minio/sha256-simd (150 MB/s using crypto/sha256).
[LINRD] 11:16:15 INFO: Hashing performance is 166.55 MB/s
[LINRD] 11:16:15 INFO: Detected upgrade from v1.11.1 to v1.12.0
[LINRD] 11:16:15 INFO: Overall send rate limit is 500 KiB/s, receive rate limit is 500 KiB/s
[LINRD] 11:16:15 INFO: Rate limits do not apply to LAN connections
[LINRD] 11:16:15 INFO: Using discovery mechanism: IPv4 local broadcast discovery on port 21027
[LINRD] 11:16:15 INFO: Using discovery mechanism: IPv6 local multicast discovery on address [ff12::8384]:21027
[LINRD] 11:16:15 INFO: Ready to synchronize db-finance-amsql (sendonly)
[LINRD] 11:16:15 INFO: Ready to synchronize "Sage-Live" (lifoj-t9ntj) (sendonly)
[LINRD] 11:16:15 INFO: TCP listener ([::]:22000) starting
[LINRD] 11:16:15 INFO: QUIC listener ([::]:22000) starting
[LINRD] 11:16:15 INFO: GUI and API listening on [::]:8384
[LINRD] 11:16:15 INFO: Access the GUI via the following URL: https://127.0.0.1:8384/
[LINRD] 11:16:15 INFO: My name is "DB-FINANCE"
[LINRD] 11:16:15 INFO: Device XXXXXXX-YYYYYYYY-YXBHKWQ-SKKANXP-EQ4OS7R-LW2D27J-DZETLGS-ET7G4QN is "backup-ns" at [tcp://backup-ns:22000]
[LINRD] 11:16:15 INFO: Device XXXXXXX-YYYYYYYY-2TABPLD-5T7YXWL-KTSXG2X-KNORWJY-RLVX7QV-YXQLCQY is "backup-ws" at [tcp://backup-ws:22000]
[LINRD] 11:16:15 INFO: Device XXXXXXX-YYYYYYYY-5PVDKQL-DQGWGGK-JLCDGBD-KFEORUI-HJCHRT6-HB732QT is "backup-co" at [tcp://10.4.1.29:22000]
[LINRD] 11:16:15 INFO: Established secure connection to GAUBTQT-3HJVQHQ-5PVDKQL-DQGWGGK-JLCDGBD-KFEORUI-HJCHRT6-HB732QT at 10.4.1.25:22000-10.4.1.29:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256
[LINRD] 11:16:15 INFO: Device XXXXXXX-YYYYYYYY-5PVDKQL-DQGWGGK-JLCDGBD-KFEORUI-HJCHRT6-HB732QT client is "syncthing v1.11.1" named "backup-co" at 10.4.1.25:22000-10.4.1.29:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256
[LINRD] 11:16:15 INFO: Established secure connection to XXXXXXX-YYYYYYYY-YXBHKWQ-SKKANXP-EQ4OS7R-LW2D27J-DZETLGS-ET7G4QN at 10.4.1.25:22000-10.5.1.29:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256
[LINRD] 11:16:15 INFO: Device XXXXXXX-YYYYYYYY-YXBHKWQ-SKKANXP-EQ4OS7R-LW2D27J-DZETLGS-ET7G4QN client is "syncthing v1.11.1" named "backup-ns" at 10.4.1.25:22000-10.5.1.29:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256
[LINRD] 11:16:15 INFO: Established secure connection to XXXXXXX-YYYYYYYY-2TABPLD-5T7YXWL-KTSXG2X-KNORWJY-RLVX7QV-YXQLCQY at 10.4.1.25:22000-10.3.1.29:22000/tcp-client/TLS1.3-TLS_CHACHA20_POLY1305_SHA256
[LINRD] 11:16:15 INFO: Device XXXXXXX-YYYYYYYY-2TABPLD-5T7YXWL-KTSXG2X-KNORWJY-RLVX7QV-YXQLCQY client is "syncthing v1.11.1" named "backup-ws" at 10.4.1.25:22000-10.3.1.29:22000/tcp-client/TLS1.3-TLS_CHACHA20_POLY1305_SHA256
[LINRD] 11:16:15 INFO: Completed initial scan of sendonly folder db-finance-amsql
[LINRD] 11:16:17 INFO: Connected to already connected device XXXXXXX-YYYYYYYY-5PVDKQL-DQGWGGK-JLCDGBD-KFEORUI-HJCHRT6-HB732QT (existing: 10.4.1.25:22000-10.4.1.29:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256 new: 10.4.1.25:22000-10.4.1.29:37604/tcp-server/TLS1.3-TLS_AES_128_GCM_SHA256)
[LINRD] 11:17:16 INFO: Completed initial scan of sendonly folder "Sage-Live" (lifoj-t9ntj)
[LINRD] 11:20:08 INFO: Listen (BEP/tcp): TLS handshake: EOF
[LINRD] 11:25:08 INFO: Listen (BEP/tcp): TLS handshake: EOF
[LINRD] 11:30:08 INFO: Listen (BEP/tcp): TLS handshake: EOF
[LINRD] 11:35:08 INFO: Listen (BEP/tcp): TLS handshake: EOF
[LINRD] 11:40:08 INFO: Listen (BEP/tcp): TLS handshake: EOF
[LINRD] 11:45:08 INFO: Listen (BEP/tcp): TLS handshake: EOF
[LINRD] 11:46:18 INFO: Sent usage report (version 3)
[LINRD] 11:50:08 INFO: Listen (BEP/tcp): TLS handshake: EOF
The TLS handshake error is my Nagios monitoring of the TCP ports. Nothing is logged to indicate a problem.
