Is syncthing limited to sending 12 megabytes per second (100 megabits)?
On our test cluster we have a rack of test machines with 10 gigabit optical cards and ssd drives. Using our distributed scripts with rsync we can easily saturate the network at 1.125GBytes/sec.
When I setup Syncthing, I noticed that a single host would limit its send speed to 12 megabytes per second; basically 100 megabit. I have maxSendKbps=0 in the config.xml file.
Ideally, I would like to allow syncthing unlimited send and receive speeds.
I would be happy to stress test syncthing with our optical networks if you could provide the patch or even the instructions to modify the source code for unlimited speeds.
