mexsudo
(Peter E)
January 27, 2023, 2:11pm
1
re: how can I force a reset? - #8 by mexsudo
syncthing --reset-database works but it is overkill
1,241,119 documents 229,275 folders ~2.76 TiB total
this folder is the only one I want to reset
Mail.Archives 3,883 documents 615 folders ~268 GiB total
Is there a method to reset the database for just One folder?
Thanks.
tomasz86
(Tomasz Wilczyński)
January 27, 2023, 2:50pm
2
No, but normally you can just remove the folder from Syncthing and then add it again, which should have the same effect (in theory, as I’ve seen posts on the forum saying that only a full reset really helped solve the particular issue).
mexsudo
(Peter E)
January 27, 2023, 3:40pm
3
thanks. I did try removing first.
I had the same problem when I added it back.
mexsudo
(Peter E)
February 12, 2023, 9:42pm
4
good afternoon all.
I hate to beat a dead horse, but resetting the database for Just One folder would sure be sweet.
Is there a way to make a feature request?
thanks
Andy
(Andreas Kaelber)
February 13, 2023, 11:58am
5
It´s not only a today discussion to have some buttons on a right place to make such operations like
syncthing -–reset-deltas
and maybe furthers. This would be good, because in each OS the parameters to start this operations are different. Both commands also could be folder related without delete and reconnecting the folder.
mexsudo
(Peter E)
February 28, 2023, 12:44pm
6
I encountered another false flag on a remote node, running Debian Bookworm
so I tried “syncthing -–reset-deltas” thinking it might be less invasive, but nope.
my system said “unknown flag” … v1.23.1, Linux (64-bit Intel/AMD)
so, it’s “syncthing --reset-database” yet again
system
(system)
Closed
March 30, 2023, 12:45pm
7
