Syncthing release v0.14.50-rc.1 don't work in Android
Hi to everybody ! Today I have downloaded the source of Syncthing for Android v0.14.50-rc.1 but when I started the compiled application I have such error :
08-08 20:53:24.881 1144-1144/com.nutomic.syncthingandroid.debug E/WindowManager: android.view.WindowLeaked: Activity com.nutomic.syncthingandroid.activities.MainActivity has leaked window com.android.internal.policy.impl.PhoneWindow$DecorView{3b8f4519 V.E..... R......D 0,0-683,224} that was originally added here
        at android.view.ViewRootImpl.<init>(ViewRootImpl.java:461)
        at android.view.WindowManagerGlobal.addView(WindowManagerGlobal.java:315)
        at android.view.WindowManagerImpl.addView(WindowManagerImpl.java:85)
        at android.app.Dialog.show(Dialog.java:338)
        at android.app.AlertDialog$Builder.show(AlertDialog.java:1009)
        at com.nutomic.syncthingandroid.activities.StateDialogActivity.showLoadingDialog(StateDialogActivity.java:135)
        at com.nutomic.syncthingandroid.activities.StateDialogActivity.onServiceStateChange(StateDialogActivity.java:75)
        at com.nutomic.syncthingandroid.activities.StateDialogActivity.bridge$lambda$0$StateDialogActivity(StateDialogActivity.java)
        at com.nutomic.syncthingandroid.activities.StateDialogActivity$$Lambda$6.onServiceStateChange(Unknown Source)
        at com.nutomic.syncthingandroid.service.SyncthingService.registerOnServiceStateChangeListener(SyncthingService.java:545)
        at com.nutomic.syncthingandroid.activities.StateDialogActivity.lambda$onCreate$0$StateDialogActivity(StateDialogActivity.java:36)
        at com.nutomic.syncthingandroid.activities.StateDialogActivity$$Lambda$0.onServiceConnected(Unknown Source)
        at com.nutomic.syncthingandroid.activities.SyncthingActivity$$Lambda$0.accept(Unknown Source)
        at com.annimon.stream.Stream.forEach(Stream.java:1479)
        at com.nutomic.syncthingandroid.activities.SyncthingActivity.onServiceConnected(SyncthingActivity.java:74)
        at com.nutomic.syncthingandroid.activities.MainActivity.onServiceConnected(MainActivity.java:295)
        at android.app.LoadedApk$ServiceDispatcher.doConnected(LoadedApk.java:1338)
        at android.app.LoadedApk$ServiceDispatcher$RunConnection.run(LoadedApk.java:1355)
        at android.os.Handler.handleCallback(Handler.java:815)
        at android.os.Handler.dispatchMessage(Handler.java:104)
        at android.os.Looper.loop(Looper.java:194)
        at android.app.ActivityThread.main(ActivityThread.java:5940)
        at java.lang.reflect.Method.invoke(Native Method)
        at java.lang.reflect.Method.invoke(Method.java:372)
        at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:987)
        at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:782)
And another error is :
8-08 21:31:02.763 8141-8224/? E/SyncthingRunnable: Failed to execute syncthing binary or read output
    java.io.IOException: Error running exec(). Command: [/data/app/com.nutomic.syncthingandroid.debug-1/lib/arm/libsyncthing.so, -generate, /data/data/com.nutomic.syncthingandroid.debug/files, -logflags=0] Working Directory: null Environment: [STTRACE=, ANDROID_ROOT=/system, EMULATED_STORAGE_SOURCE=/mnt/shell/emulated, LOOP_MOUNTPOINT=/mnt/obb, USBOTG_STORAGE=/storage/usbotg, ANDROID_BOOTLOGO=1, EMULATED_STORAGE_TARGET=/storage/emulated, STNORESTART=1, STHASHING=minio, STGUIASSETS=/storage/emulated/0/Android/data/com.nutomic.syncthingandroid.debug/files/gui, EXTERNAL_STORAGE=/storage/emulated/legacy, SYSTEMSERVERCLASSPATH=/system/framework/services.jar:/system/framework/ethernet-service.jar:/system/framework/wifi-service.jar:/system/framework/hwServices.jar:/system/framework/hwcustservices.jar:/system/framework/hwWifi-service.jar, ANDROID_SOCKET_zygote=11, PATH=/sbin:/vendor/bin:/system/sbin:/system/bin:/system/xbin, ANDROID_DATA=/data, ANDROID_ASSETS=/system/app, ASEC_MOUNTPOINT=/mnt/asec, HOME=/storage/emulated/0, BOOTCLASSPATH=/system/framework/core-libart.jar:/system/framework/conscrypt.jar:/system/framework/okhttp.jar:/system/framework/core-junit.jar:/system/framework/bouncycastle.jar:/system/framework/ext.jar:/system/framework/framework.jar:/system/framework/telephony-common.jar:/system/framework/voip-common.jar:/system/framework/ims-common.jar:/system/framework/mms-common.jar:/system/framework/android.policy.jar:/system/framework/apache-xml.jar:/system/framework/hwEmui.jar:/system/framework/hwTelephony-common.jar:/system/framework/hwAndroid.policy.jar:/system/framework/hwframework.jar:/system/framework/hwcustframework.jar:/system/framework/hwpostcamera.jar:/system/framework/hwcustTelephony-common.jar:/system/framework/hwcustAndroid.policy.jar:/system/framework/org.simalliance.openmobileapi.jar:/system/framework/mediatek-common.jar:/system/framework/mediatek-framework.jar:/system/framework/mediatek-telephony-common.jar, ANDROID_PROPERTY_WORKSPACE=9,0, STNOUPGRADE=1, SECONDARY_STORAGE=/storage/sdcard1, ANDROID_STORAGE=/storage]
        at java.lang.ProcessManager.exec(ProcessManager.java:211)
        at java.lang.ProcessBuilder.start(ProcessBuilder.java:195)
        at com.nutomic.syncthingandroid.service.SyncthingRunnable.setupAndLaunch(SyncthingRunnable.java:464)
        at com.nutomic.syncthingandroid.service.SyncthingRunnable.run(SyncthingRunnable.java:136)
        at com.nutomic.syncthingandroid.service.SyncthingRunnable.run(SyncthingRunnable.java:107)
        at com.nutomic.syncthingandroid.util.ConfigXml.<init>(ConfigXml.java:69)
        at com.nutomic.syncthingandroid.service.SyncthingService$StartupTask.doInBackground(SyncthingService.java:337)
        at com.nutomic.syncthingandroid.service.SyncthingService$StartupTask.doInBackground(SyncthingService.java:322)
        at android.os.AsyncTask$2.call(AsyncTask.java:292)
        at java.util.concurrent.FutureTask.run(FutureTask.java:237)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1112)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:587)
        at java.lang.Thread.run(Thread.java:831)
     Caused by: java.io.IOException: No such file or directory
        at java.lang.ProcessManager.exec(Native Method)
        at java.lang.ProcessManager.exec(ProcessManager.java:209)
Please help to solve it.
Everything works - I did not build the library properly
