Hi, I installed Syncthing on my QNAP NAS from here:
All works good and I can also add Folders and the Folders will be syncronized.
But how can I access my files on the NAS?
Default Path was /home/syncthing/
User ‘syncthing’ on NAS was created after installing Syncthing.
But I can’t login with User syncthing to NAS because I don’t know the password. Is there a default password? To set the password for that user failed on NAS.
I can’t access /home/syncthing/ with my “normal” QNAP User…
I think is same as to Synology, in that way, that a user or group is also installed, maybe called “sc-syncthing” or similar and that you need to connect to the folders. Maybe a reboot of the NAS is needed.
