I will soon use a beter router/server by using the new BananaPi router (BPI-R1 : http://www.bananapi.com/index.php/component/content/article?layout=edit&id=59)
It runs OpenWRT (router/server applications and allow to use a intern SSD hard drive).
Here are some specifications.
Thanks to create a OpenWRT package of Syncthing (http://wiki.openwrt.org/doc/devel/packages)
Hardware specification
CPU A20 ARM Cortex™-A7 Dual-Core
GPU ARM Mali400MP2Complies with OpenGL ES 2.0/1.1
Memory (SDRAM) 1GB DDR3 (shared with GPU)
Onboard Storage Micro SD (Max. 64GB) card slot UP to 2T on 2.5 SATA disk
Onboard Network 10/100/1000 Ethernet RJ45, WLAN @802.11b/g/n
Video Input
A CSI input connector allows for the connection of a designed camera module
Video Outputs HDMI , LVDS/RGB
Audio Output
Audio Input 3.5 mm Jack and HDMI
Microphone
Power Source
5 volt via Micro USB(DC In Only)
USB 2.0 Ports
USB Host and Micro USB (OTG) USB Host
Buttons
Reset button: Next to Power button
Power button: Next to Battery connector
GPIO(2X13) pin
GPIO,UART,I2C bus ,SPI bus with two chip selects,
CAN bus,ADC,PWM,+3.3v,+5v,ground.
LED
Power Key & RJ45
Remote IR
OS Android 4.2, Linux
Interface definition
Produxt size 148 mm × 100mm
Weight 83g
