Syncthing on nvidia shield tv pro
I can’t seem to specify a pathway to the external hard drive on my nvidia shield tv pro. Syncthing keeps trying to put the files in syncing from my phone directly onto my shield and not the external hard drive. Is there a way to fix this as the app looks to be meant for mobile and hard to use on the shield tv. Thanks for the help
I’d try using the Web GUI (accessible from the left slide-out menu) and inputting the full path manually there. You may need to use ADB and command line tools to find the actual path to the external drive though.
Thing is I can’t change that with the bad interface on shield tv. Maybe if I had a wireless mouse and keyboard for shield tv. It’s really hard to use on this platform
