Hey I followed the steps for setting up syncthing on CentOS 7 from this website. But when I start the service i get the following message:
Sep 14 10:45:10 localhost systemd: Started Syncthing - Open Source Continuous File Synchronization for rndlnxadm.
Sep 14 10:45:10 localhost syncthing: [start] INFO: syncthing v1.18.2 "Fermium Flea" (go1.17 linux-amd64) teamcity@build.syncthing.net 2021-08-22 18:04:47 UTC
Sep 14 10:45:10 localhost syncthing: [23JDG] INFO: My ID: 23JDGFK-RZSEQB7-FZRUWI6-2MEDIT3-EM2W7L6-XCEUWHJ-R43FUW5-ADOCOAW
Sep 14 10:45:11 localhost syncthing: [23JDG] INFO: Single thread SHA256 performance is 123 MB/s using crypto/sha256 (123 MB/s using minio/sha256-simd).
Sep 14 10:45:11 localhost syncthing: [23JDG] INFO: Hashing performance is 108.62 MB/s
Sep 14 10:45:11 localhost syncthing: [23JDG] INFO: Overall send rate is unlimited, receive rate is unlimited
Sep 14 10:45:11 localhost syncthing: [23JDG] INFO: Ready to synchronize "Default Folder" (default) (sendreceive)
Sep 14 10:45:11 localhost syncthing: 2021/09/14 10:45:11 failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/lucas-clemente/quic-go/wiki/UDP-Receive-Buffer-Size for details.
Sep 14 10:45:11 localhost syncthing: [23JDG] INFO: Using discovery mechanism: global discovery server https://discovery.syncthing.net/v2/?noannounce&id=LYXKCHX-VI3NYZR-ALCJBHF-WMZYSPK-QG6QJA3-MPFYMSO-U56GTUK-NA2MIAW
Sep 14 10:45:11 localhost syncthing: [23JDG] INFO: Using discovery mechanism: global discovery server https://discovery-v4.syncthing.net/v2/?nolookup&id=LYXKCHX-VI3NYZR-ALCJBHF-WMZYSPK-QG6QJA3-MPFYMSO-U56GTUK-NA2MIAW
Sep 14 10:45:11 localhost syncthing: [23JDG] INFO: Using discovery mechanism: global discovery server https://discovery-v6.syncthing.net/v2/?nolookup&id=LYXKCHX-VI3NYZR-ALCJBHF-WMZYSPK-QG6QJA3-MPFYMSO-U56GTUK-NA2MIAW
Sep 14 10:45:11 localhost syncthing: [23JDG] INFO: Using discovery mechanism: IPv4 local broadcast discovery on port 21027
Sep 14 10:45:11 localhost syncthing: [23JDG] INFO: Using discovery mechanism: IPv6 local multicast discovery on address [ff12::8384]:21027
Sep 14 10:45:11 localhost syncthing: [23JDG] INFO: QUIC listener ([::]:22000) starting
Sep 14 10:45:11 localhost syncthing: [23JDG] INFO: TCP listener ([::]:22000) starting
Sep 14 10:45:11 localhost syncthing: [23JDG] INFO: Relay listener (dynamic+https://relays.syncthing.net/endpoint) starting
Sep 14 10:45:11 localhost syncthing: [23JDG] INFO: Completed initial scan of sendreceive folder "Default Folder" (default)
Sep 14 10:45:11 localhost syncthing: [23JDG] WARNING: Failed starting API: listen tcp: address tcp/8384": unknown port
Sep 14 10:45:11 localhost syncthing: [23JDG] INFO: Relay listener (dynamic+https://relays.syncthing.net/endpoint) shutting down
Sep 14 10:45:11 localhost syncthing: [23JDG] INFO: QUIC listener ([::]:22000) shutting down
Sep 14 10:45:11 localhost syncthing: [23JDG] INFO: Detected 0 NAT services
Sep 14 10:45:11 localhost syncthing: [23JDG] WARNING: Starting API/GUI: listen tcp: address tcp/8384": unknown port
cSep 14 10:45:12 localhost syncthing: [23JDG] INFO: TCP listener ([::]:22000) shutting down
Sep 14 10:45:12 localhost syncthing: [23JDG] INFO: Exiting
Sep 14 10:45:12 localhost systemd: syncthing@rndlnxadm.service: main process exited, code=exited, status=1/FAILURE
Sep 14 10:45:12 localhost systemd: Unit syncthing@rndlnxadm.service entered failed state.
Sep 14 10:45:12 localhost systemd: syncthing@rndlnxadm.service failed.
Sep 14 10:45:13 localhost systemd: syncthing@rndlnxadm.service holdoff time over, scheduling restart.
Sep 14 10:45:13 localhost systemd: Stopped Syncthing - Open Source Continuous File Synchronization for rndlnxadm.
And it keeps restarting over and over again. I tried the guide on CentOS 8 but there’s no issue so far. Is there something I should change or reconfigure? Thanks
