First of all, thanks to all the people who put their effort into this. It looks really really promising.
Unfortunately I did not manage to get it running on my pi yet.
I installed it by modifying a PKGBUILD in the AUR, so that it would install the armv6 version of syncthing.
However, after starting it in systemd, the admin interface keeps stating that I should restart syncthing - starting it directly from the console leads to the following messages, after setting the appropriate STTRACE variables (“mc”)
I doubt that’s related; that’s most likely from trying to announce on the ifb0 or ifb1 interfaces, whatever those are. What does the full startup look like, sans debugging options?
Ok, you’re right. Syncthing seems to run just fine, the problem was, that I had deactivated JavaScript - A reminder to activate it would be nice here.
Ok, so now I have connected two nodes. I exposed both hosts on 22000. So now, when I change a file on my desktop, the Pi gets some information but tells me:
11:36:14.976: Connection to desktop closed: unexpected EOF
It seems to be working though.
Well, I guess I can live with that. Thanks for your feedback!
I hope it’s okay to hijack this thread. I have a similar setup, Arch Linux on a Raspberry Pi. My network configuration is fairly simple and works, but when I start syncthing I get the following log:
[FIXZT] 2014/05/13 22:48:11 INFO: syncthing v0.8.5 (go1.2.2 linux-arm) jb@jborg-mbp 2014-05-11T18:46:09Z
[FIXZT] 2014/05/13 22:48:11 INFO: My ID: XXXXXXX
[FIXZT] 2014/05/13 22:48:11 INFO: Starting web GUI on http://127.0.0.1:8080/
[FIXZT] 2014/05/13 22:48:11 INFO: Populating repository index
[FIXZT] 2014/05/13 22:48:14 INFO: No UPnP IGD device found, no port mapping created (read udp4 0.0.0.0:40455: i/o timeout)
[FIXZT] 2014/05/13 22:48:14 INFO: Sending local discovery announcements
[FIXZT] 2014/05/13 22:48:14 INFO: Sending global discovery announcements
[FIXZT] 2014/05/13 22:48:14 OK: Ready to synchronize default (read-write)
mc: 22:48:14.711964 beacon.go:94: write udp4: network is unreachable
Then nothing more happens. Any ideas how to fix this?
Nothing more, as in it fails to connect to any configured peers and so on? The first step would be to check for firewalls, perhaps hard code an IP address for a peer to see if the problem is discovery or connectivity.
