Hi everybody,
can somebody tell me where (in android) is the config file for Syncthing? I want to access Syncthing (the one on my note 20) from my laptop…
Thank you all!!
Hi everybody,
Thank you all!!
You really shouldn’t try to modify the config file on Android directly. Normally you just set the GUI listen address to 0.0.0.0 and then access the GUI remotely using the phone’s local IP address, e.g. http://192.168.0.2:8384, etc.
Just for the record, the config file on Android is located inside the Syncthing folder on the /data partition and can’t be accessed without root.
Thank you.
I will Try this.
