I have SyncThing running on different devices, now I wanted to set it up on my RASPI where pi-hole is already running fine in a Docker Container with Portainer…
My problem is that I can find the defined folders on the host (outside of the container) so far so good but there is nothing in it but it should… SyncThing says 2 files are syncroniesed and that would be great. So I’m assuming the two test files are send from my Notebook to the Raspian but they don’t seam to get out of the container…
What can I check?
