Will the binary for Linux run on this hardware (4GB RAM)? I read the RPi’s are 32bits, so can install/updates be done as stated @ https://apt.syncthing.net/ ?
I’d like to set a “Receive only” Folder for about 10GB. Do you know any obstacle(s) that will make me fail ?
Beeing a fullNewb on Rasp and halfNewb in linux, I’ll stick for a while to Raspbian which is 32bits AFAIK and I read somewhere some 64bits distros are not supported and may have bug(s?) with the GPU or video thing. Before you replied I went to wander I’d use syncthing for Android because of the ARM proc.
Raspbian is a derivative of debian and as such the aptitude/apt/.deb versions will work fine on a raspberry. Installing via apt will take care of installing a compatible architecture.
For raspbian that will probably be armv7l (32 bits) even though the newer raspberrys have an armv8 (64 bits) processor - the official raspbian image has not changed (yet) afaik. Some day probably.
This means for syncthing that the limits of this architecture apply, e.g at most ~3GB of virtual memory can be addressed.
